libertyman
- Joined
- Jan 28, 2007
- Messages
- 111
- Reaction score
- 0
I was thinking of adding the tubular sidesteps to the liberty, mine is a 03, I found a wrecked 07 with the tubular sidesteps, will they bolt right on my jeep?
If they are the factory rails, and if they didn't change the mount locations between years they should work. You'll need some of the infamous 'nut-serts', but all the holes you need should already be in the frame. As for the plastic trim pieces under the rocker panel, they'll pop right off.I don't think even the original ones will bolt right on. You would need to drill. Also 05+ has that weird plastic blob at the bottom, not sure if that'll be on the way.
