twack
I saw someone say that the 2002 liberty can only be lifted 1.5 inches and not 2.5 because of something with the control arms. can any one tell me more how bad is this and how do i fix it?
As far as I know the stock UCAs are the same design between years, so you wouldn't gain anything.so couldnt i just use the control arms from a 03 on up?
Your '02,even if it is a pre-lowered,is sagging pretty bad now anyways and the struts/shocks are shot so it won't matter,you'll be lucky to get 1.5" with a 2.5" spacer.Just opt for new struts/shocks and new coils and be done.
I'm curious to know just how much it would cost to do this. I'm not looking to run the Rubicon, but would like a decent lift more for ride quality than anything else. 2 1/2-3 inch would be great. Is the Frankenlift 1 still available? I'd rather go the springs, shocks, struts route than just pucks and spacers. Any suggestions?
That has to do with the '02 being pre-lowered...
In a test a journalist rolled a KJ on a slalom course. That scared DC and so '03 and upwards they lowered the suspension around 1".
So... yours sits higher already then the '03+ ones. But I've never heared anything going bad with the Daystar 2.5" on an '02 so don't worry about it.
I just put the Daystar 2.5" kit on my pre-lowered '02 a week ago and love it, can't beat it for the price - of course I don't have any experience with any of the other lift kits, obviously it would be ideal to replace the springs and shocks altogether but for $150 you won't hear me complain. My '02 already sat at least an inch higher than my mom's '05, even with the smallest of the factory tires. Now, mine sits MUCH higher, I'll post some pics up here in the next few days, and I'll also be reviewing the 245/75 re-treaded MTs I put on at the same time.
so you have an 02 and did not replace the front and rear shocks only lifted it with a spacer lift ?
No upgrade to Rancho's from the factory(at least in the USA),I worked at a Jeep dealership when the KJ came out,early '02 shocks still sucked as bad a '07's,I know I have a early pre-lowered KJ that the OEM stuff was totally shot at less then 10,000 miles.Tom, you say every time that the OEM shocks are done at around 30/40K miles...so does TJKJ...
But my stock shocks seem fine after 90k...even the rear ones seem to work fine, even after I battered them with the Daystar 2" 'upgrade'...
Maybe things changed later on? Maybe the first batch of KJ's had a better quality shock?
Funny enough, back in '02 you could get an upgrade right from the factory of...RANCHO shocks!
Mine are still firm after 61k.....not going to replace anything for a while. Of course, mine was driven all highway before I got it, and I don't live in the "Rust Belt" so that probably adds life to it....
You can lift a "pre-lowered" '02 KJ just as high as any other KJ.April 12th 2002 is when they lowered the KJ's by 3/4" via by shorter coil springs.Your '02,even if it is a pre-lowered,is sagging pretty bad now anyways and the struts/shocks are shot so it won't matter,you'll be lucky to get 1.5" with a 2.5" spacer.Just opt for new struts/shocks and new coils and be done.
