Question about backlight
Joer115
New Jersey
I tried searching and couldn't find anything. My fiances 2006 Jeep liberty3.7L her backlight behind the AC control knobs half side of it is out, I'm just wonering if there is a how to or any advice on replacing the bulb. I hope it's just a bulb behind there that went out. Just haven't taken that center console out yet? Any help would be much appreciated.
(1) To Remove Trim Panel:
the screw from inside the cubby bin
next to the power outlet.
(2) Using a trim stick C-4755 or equivalent,
remove the center bezel from the instrument panel
assembly.
Once trim panel is off you will find:
More screws to remove the Heater control assembly.
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the center bezel from the instrument
panel.
(3) From the back of the center bezel, use a small
thin-bladed screwdriver to rotate the heater-A/C control
illumination bulb holder counterclockwise about
30 degrees on the circuit board.
(4) Pull the heater-A/C illumination bulb holder
and bulb straight out of the circuit board bulb
mounting hole.
Installation:
(2) Insert the heater-A/C control illumination bulb
holder and bulb straight into the circuit board bulb
mounting hole until it is firmly seated (Fig. 11).
(3) Using a small thin-bladed screwdriver, rotate
the heater-A/C control illumination bulb holder clockwise
about 30 degrees on the circuit board.
(4) Reinstall the center bezel onto the instrument
panel.
(5) Reconnect the battery negative cable.
