Black03Limited
Well, took the liberty to a shop to install a new connector for the rear speed sensor. No luck. Still getting the ABS and brake warning lights and speedo is still acting funky. The mechanic said he thinks it may be the module that controls the ABS?? I am assuming its the Powertrain control module? Or is it the Body control module?
This is after a new connector, and a new sensor and changing the rear differential fluid out.
I do not understand. The mechanic says he does not believe the tone ring is bad either because when he spins the wheels, he seems to be getting a constant reading from the rear sensor. I dont understand what else it could be? Of course this is just my luck. It cant be anything 'normal' or easy.
What do you guys think? I am at my wits end and now find out i could need a new control module that could cost up to 1000 dollars?? I cant drop that kind of cash without being 200% sure its going to do the trick.
