I also used the Bosch Platinum +2 in my 3.7, and I will be leaving them in for the duration of the vehicles life, unless I fall upon a set of Diamond Fire plugs cheap or free. Platinum will last up to three times longer than Copper tip plugs. My avenger came with NGK Platinum plugs, and; I changed them at <= 70K (60K is the change interval), and used +4s, and never changed them since. I traded it in for this jeep, at over 150K miles with those in it, ran smooth as ever. Japanese engineering helps with all the counter weights on the crank of the 6G73, you could hardy ever tell the car was running. Very reliable engine, was smooth always, just like the 2.0 (1990cc) I4 I had in my 1969 BMW 2002. I mentioned elsewhere it was a 79, was a type-o, they were a 1968 to 1976. All lettering and gauges were in German too, was cool...
You can use SeaFoam to clean the induction system. Follow the directions. My tube blew off the nozzle, and went into the intake. Where it is? Who knows. I have put 6k miles on it since, and I don't know where the plastic tube is, or what happened to it. With my avenger, I removed the intake plenum and soaked it in kerosene, then Sea Foamed it clean. I did that at the same time I changed the plugs, as I was going to change the valve cover gaskets, only the plug valley seals were leaking, but I could not get the covers off. So, I wrapped each plug TOP, where it seals into the valley, in three layers of electrical tape, put them back in, no more leaks.
ANYHOW; You will get many opinions, this is what I do, HAVE been doing since 1987, my cars last and run just fine, till they rust out completely out, so whatever. The only two reasons I got rid of the Avenger? I was tired of having a sled in the winter, and the bottom of rear wheel wells were rusting out, and a jack almost went through the body of the driver side, at the rear jack point. Did not want to invest in the body, and weighed the options with a 4x4 in winter, and that won out.
Platinum plugs rare cool...
