PCV value replacement
mindbomb
California
How do you replace the PCV valve? looks straightforward but:
1- rubber hose connected feels "welded" to the valve
2- no way to turn the valve downward 90 degrees (block by metallic pipes, AC?)
any tips? thanks
Get a Mopar one for starters. And do it when the engine is warm, use a screw driver to push the hose off. The pipes won't prevent it from coming out. That whole filler tube assembly will move a little.
Yeah, like HJ says. OEM or NAPA also work good. They come out hard. Hang on to the filler neck. Push the PCV in a little and turn counter clockwise at the same time. Buy the replacement first in case you break the old one. I broke one the first time I changed mine and keep a spare in the garage.
My hose was welded on, I ended up using a hair dryer to heat it, then use flat screwdriver to get it off the PCV.
Here is the Mopar part#...
[/URL]
They can get plugged with foamy type gunk, more so in winter...
[/URL]
There is a TSB that replaces the small PCV and moves it away from the filler neck all together.
No more headaches with the updated PCV system.
Link: http://www.jeepkj.com/forum/f202/upgrade-your-pcv-system-tsb-25-001-08-a-59416/
page 2 list all the part #s from Brian.
Leeann
Maryland
Yep, have the new one there. Breaking the old one makes it easier to remove...
