eradicator006
I have a 2005 Liberty. 4 wheel disc with abs.
Yesterday I was entering on to the freeway. As I was about to merge in to traffic at 55 mph I heard a loud thumping noise coming from the back. At first I thought a semi truck came out of nowhere and turned on it's engine brakes. That wasn't the case. I pulled over and looked underneath the jeep looking for obvious signs of something. Nothing caught my eye. I started driving again and no more noise. The noise didn't appear again until this morning. I dropped my wife off at work and the noise was gone.
Later today I wanted to dump off my old oil so I could use my drain pan so I can change my diff fluid. I was thinking there was something wrong with the diff. I started driving to the depot with no troubles. No noises of any kind. I then started driving home and I had the window down. I hear a distinct squeak squeak squeak then thump thump thump. I made it home (wasn't far). Noise quit by the time I got home.
After all of that I took a break. I eventually got around to looking at things. I deciding to pull up on the parking brake. I hear a weird jingle noise from the back and also a weird clunk. I started up the jeep and put it in reverse. It didn't want to move freely. Required a bit of gas to move when normally it would roll on it's own. I pull up on the parking brake a few times and drive forwards and backwards. Eventually the brakes freed up. Went for a drive and things were good for a bit. Eventually the squeak squeak squeak started up. Eventually turned in to a thump thump thump. Jeep felt sluggish and dragging.
So....seems my parking brake is acting up, right? I don't think the main pads are sticking. There is no brake dust on my wheels. The main pads looks fine them selves (didn't look at parking shoes yet). The rear passenger wheel was very hot while the drivers side was just hot (not too hot but hotter than the fronts). I can also smell burning brakes faintly.
Basically what I need to know is what do I do now? I've done brakes before on older vehicles but nothing with abs. Is there some way I can disconnect the parking brake? I don't use the thing anyway.
