DAGtunes
So I've got my 2005 Jeep Liberty Renegade in for 60K mile schedule "B" maintenance at my local mechanic (not the dealer). I tow a 3500lb pop-up tent trailer about 10-15 times per year, and do some light off-highway driving, mostly in 4HI. (command-trac)
The menchanic informed me that he found metal "chunks" in the rear differential fluid, and so he opened the case to clean it out and said the "spider gear" teeth are obviously worn, and chipping. He recommends replacement, if I plan to continue towing with this vehicle. (Which I do...maybe.)
He contacted Mopar parts, and they say they do not sell the "spider-gear" set seperately, but only as a unit, due to the command-trac system requirements. $267.00 for parts - assuming the bearings and everything else are OK. Labor - $400.00.
The mechanic claims that he's seen this with other Dodge/Jeep vehicles.
I know very little about transmissions/differentials.
1st question: Do you think I'm being taken advantage of? I will definitely be asking to see the parts after the repair.
2nd question: Is this common? (Only 60K miles, towing within specs, no real abuse of vehicle...) I read up on the diff's in the Libby, and they are all aluminum, vs. steel used in other brands. Could that be a contributing factor?
Anyway, any advice on how to proceed here? Things to watch for, etc.
Any Help/Advice would be appreciated!
