Opinion on Lift
Discussion in 'Lift Kit Discussion' started by jeeplib05, Jan 11, 2016.
  1. jeeplib05
    jeeplib05 Full Access Member
    851
    Jan 7, 2016
    Ohio
    What's up guys,
    I've got a couple questions as I have zero experience with lifts..
    So I recently got a 05 Liberty Sport 3.7L and of course, I'm wanting a lift. I found this combo by JBA Tommudd's Econo 3.5" Lift Kit I think it has a great combo of everything needed to get the lift I want, considering I didn't want anything more than 3", but hell, I can go to 3.5" :emotions34: Also, it has options for clevis spacers, and says the 0.375" spacer is the typical one people buy. Should I get this as well?
    Thoughts on this? Is this worth the $1,400+? Should I add anything else to the list? If so, I don't mind saving up some money and getting it, but I don't want to spend that much on something that isn't a good combo of upgrades. Looking for good ride quality on/off road (not serious off roading). Thanks in advance !
  2. profdlp
    profdlp On The Ledge
    4,929
    203
    Pure crap! :favorites68:
    ^^ THAT'S A JOKE!!! ^^ :happy175:
    Tommudd is one of the moderators here and many members have gone with that package and been extremely happy. I can't recall anyone not liking it. :favorites13:
  3. jeeplib05
    851
    Jan 7, 2016
    Ohio
    So does this kit have everything I'll need to lift my Liberty or do I need to purchase more things?
  4. profdlp
    4,929
    203
    I'll leave it to the pros, but I think you might need some hockey pucks for bumpstops. You could buy Al's, too.
    This is the kit I hope to be getting soon. (Real soon, if Uncle Sam cheated me as much as I think he did.)
  5. CzarKJ
    CzarKJ Full Access Member
    2,605
    Mar 3, 2013
    Townsend, MA
    Ya looks like just add bump stops. 2 hockey pucks for the rear and terraflex extended for the front.
  6. tommudd
    tommudd Moderator Staff Member Moderator
    17,578
    332
    Several questions, first is which front springs are you going with?
    If Ironman go with the .500 clevis, if OME go with the .375 onesYou also should get the teraflex front bumpstops, for the rear 2 hockey pucks per side bolted down to the spring perch work great.
    Any questions let me know
  7. jeeplib05
    851
    Jan 7, 2016
    Ohio
    Hello Tommudd,
    I am wanting to get the Ironman lift. What size Teraflex front bump stops should I buy? Thank you for the info everyone ! Now it's time to save up and hope that I install it right ...
  8. profdlp
    4,929
    203
    There are plenty of good write-ups here to keep you busy reading while you're salting away the dough. Good luck! :)
  9. tommudd
    17,578
    332
    There is only one size of the teraflex bumpstop
    Then after you buy them cut a notch in the very bottom to clear the grease zerk if and when it hits
  10. 4x4kayak2112
    4x4kayak2112 Full Access Member
    750
    Jul 16, 2009
    tx
    From personal experience with both OME and Ironman LONG TERM on my personal Jeeps, definitely go with the OME.
    Sent from my SM-N900P using Tapatalk
  11. jeeplib05
    851
    Jan 7, 2016
    Ohio
    Better ride quality over time or do the parts have more durability? I plan to lift it whenever I get the money and would obviously like it to last the life of the vehicle or close to it.
  12. tommudd
    17,578
    332
    OMEs seem to last a while longer , ride is the same basically between both
    I've had my 04 (I bought new fall of 2004) lifted almost 200,000 miles now
    first lift was a OME that I removed at 100,000 miles and swapped to another KJ , had another OME after that, an Ironman for a while ( with long term testing done on a friends KJ , still running it with no issues over 3 years later and still within 3/8 inch of where we sit it up that first day ) and now JBA coilovers.
    Been playing with KJ lifts since very early 2005 and lifted a ton of them with Ironman, OME and the coilovers
  13. jeeplib05
    851
    Jan 7, 2016
    Ohio
    So if I get the TM Econo 3.5" lift (Ironman) with the .500" clevis spacer will I run into any issues with the CVs or anything? With the clevis spacer being another half inch the JBA site says you get about 1" of lift, which would take me to 4.5" and then a little under after it settles, correct? Just don't want to have to repair major stuff since I have to spend so much on the lift let alone get new tires/wheels to make it proportional
    Thank you for the help by the way, I've never done major modding considering I owned a 2000 Grand Prix before this LOL
  14. tommudd
    17,578
    332
    4.5 inches would be way too high
    No , with the Ironman you get 2.25 inches of lift, add a .500 spacers brings you to 3.25, add the 1/4 inch top plate and you'll be at 3.5-when settled in
    Better would be the OME springs though with a .375 inch spacer, OME is seeming to last a bit longer (for some)
  15. 4x4kayak2112
    750
    Jul 16, 2009
    tx
    What tom said on all points. The Ironman/OME stay happy up until around 3.75" lift. After that you have alot of spring/arm contact.
