OME N132 rear shock
jggv98
Monterrey
Finally I have installed the OME HD suspension on my 2004 KJ, the rear shocks are the standard length N132, my question is, can I put an extra isolator on the rear suspension with the OME 948 springs? If the answer is yes, which one should I use, the upper or lower iso?
I think the lower one is thinner than the upper
I also have 2 hockey pucks on each side like bump stops
Thanks!
132Ls are for lifted KJs
132s are stock
so answer would be no
BUT if you had the 132Ls it would be upper iso's
jggv98
Monterrey
Thanks!
My mistake in choose N132 instead the long travel, they were on back order
How much extra lift could I have with an extra upper isolator? I gain 3" with the 948 springs
