OME and CRD?
TwoBobsKJ
Northern Ohio
has anyone lifted their CRD with the OME suspenison? or know anyone that has?
There are discussions here in the Lift Kit forum and also over on LOST about CRD lifts. The correct part number for the OME front springs for the CRD is OME790 - you can then use the HD rear springs just like the gassers, part number OME948.
Hope this helps...:party52:
If you look at the ARB/OME website it will tell you to use either the OME 927s for the front or the 790s .
Stock spring rate is 410 lb and the 927s are 400 so you would retain the stock ride basically with some lift. Now the 790s is what most go to and they are rated at 500 lb so much stiffer and will go good with an aftermarket bumper.
You can also check out the Frankenlift which uses the 790s in the front.
bugnout
Illinois
I'm running the OME 790's front and 948's rear. Have steel front and rear bumpers and winch.
