69moparfan
I just picked up an '02 with a blown head gasket, and the dreaded valve seat drop (1 on each bank #2 & #5 ).
While I am in the front I figured I would replace the tensioners, chain slides, and the oil pump.
The pump appears to be readily serviceable, but the FSM states that the pan has to be removed to do so. Looks like 1 bolt to drop the pickup, but does the pan interfere with removal somehow?
