southernwake
When I was changing the oil on my wife's libby I noticed that there was some blow by oil residue on the bottom of the oil pan and transmission bell housing. So I inspected and found the culprit I believe. On the rear driver's side of the oil pan I see that it is wet up at the top where it mounts to the bottom of the engine. So I think the gasket is bad and it is leaking when we are driving it. There are no drip spots in the driveway when it sits overnight. But I am losing a little less than 1/2qt every 2500 miles or so.
I am going to try and get it changed out here as soon as I can, hopefully this weekend if everything works out. I figured while I was doing this I would go ahead and change the motor mounts since they will have to be unbolted anyways to give me enough clearance to lift the motor up. Anything else you guys would recommend to go ahead and and change or look at while I have that pan unbuttoned?
Thanks
Andrew
Thanks
Andrew
