Oil Leaking Behind Filter
frcctv
Colorado
Have an 06 KJ Sport v6 3.7. Oil leaking from what appears to be behind the
oil filter. I tried changing the filter several times and after some time on the road, the filter is covered in oil. So i don't think its the filter itself but the assembly its attached to. Anyone know what this "assembly" is called and how easy it would be to replace. I called around to advance and oreilly auto parts but they seem to have no idea what the hell I am talking about.
Leeann
Maryland
I first thought of an old gasket. Easy to leave behind.
Then the oil pressure sender if no extra gasket on the mount.
Then check the oil pressure sending unit right above the filter like uss2defiant said.
cohgpilot
If your 2002 Jeep Liberty with a 3.7L engine is experiencing a coolant leak near the oil filter housing, the most likely culprit is a faulty oil filter housing gasket; this gasket seals the coolant passages within the housing and can leak if worn or damaged, causing coolant to drip from the area around the oil filter. https://www.ebay.com/itm/133355841886
As an eBay Associate we earn from qualifying purchases.
Shankster
Durango, Colorado
Here is a 3rd vote for the oil pressure sender. I would replace it rather than trying to tighten it (they are fragile and can break off). It takes a big deep socket to get it on and off (I think 27mm or 1-1/16"). You can't get a wrench in there. It may be hard to get to - I did mine with the engine out and on an engine stand. Goop some non-hardening form a gasket on the threads before you install the new one.
cohgpilot
Adding to this: if it is an earlier 2000s liberty it does not have the oil filter gasket. But it does have 2 o rings under the timing cover at the front left and right of the engine where coolant could leak from and end up in the same spot under the oil filter.
