BillyBones
Quick question, you buy a new jeep and it's 0 on the odometer, what do you think is the target for the first change. I know what the manual says, but I was just curious on people's thoughts.
I guess I will waste my money then.From rebuilding engines and learning proper break in,the first thing I did when I got my KJ was drain the oil(at 4 miles) and put in non detergent oil,changed at 500 miles with regular oil.At 1000 changed it again,refilled with synthetic,at 2000 changed it again,and then again at 3000.After that did oil changes at 3000 miles with Mobil 1 and either a Napa Gold filter or PureOne filter.Got to flush all the metal shavings out that will be produced by a engine breaking in and forming it's wear patterns.Do a google on the subject. 3k miles for years has been the norm, but with todays improved oils, 5k is becoming the new norm... even higher with synthetic oils. 1.5k is overkill and a waste of time and money....
ChiefRudy, wish I was you. 24k after 15 or so months.
Flush my ****** every 15,000,change the filters at 30,000.Diffs get changed every 12,000,the t-case every 6000miles.Powersteering fluid every 12,000,coolant(and hoses,t-stat) every 3 years.All synthtic except the coolant.Fuel filter every 30,000,plugs every 30,000,and the serp belt at 30,000.Wash my air filter every month or when looks dirty(AEM dryflow filter).Last but not least rotate my tires every 3000 miles.Wow tjkj, and I thought some people would call me crazy! Youre up on those oil changes.
How often did you say you changed he ****** oil? Diff oil?
I do push my KJ harder then most and from years of wrenching and rebuilding engines,trans,t-cases,and diffs I see the benifit from changing fluids at a regular interval.Plus most lubricants are being cheaply made these days due to high crude prices.thats because those do not have to be done that often. im not sure if he just likes to work on his jeep that often or hes paranoid that these engines or like thin glass and are very fragile. also im sure he does more offroading then most and pushes it more which may lead to maintance more often but i dont see why with the powersteering that often, thats unheard of. I know many mechanics, ranging from dealer mechanics to mechanics who own their own shop and they have never heard of having to do so much maintance that often on some of those things hes listed. Heck at work right now i got 6 mechanics around me and none of them think ****** and power steering need to be done that often, even if your pushing the vehicle harder then most.
Engines these days are built to last up to 300k+ if maintained and following the service manual. With the advance in the oils used in the powertrain, it keeps everything running much smoother and cleaner, thus preventing so much maintance that often.
If you ad it up over time, all the time and money put into doing everything double as much as you have to, you could have added that money up for a motor rebuild when it does go at 300k.
If parts are going to break prematurely its because of a defect when it was made, no matter how much new oil you throw at it, if its defective, its going to break anyways.
People who put crap generic cheap oils in their vehicle, usually have more problems, if you use the proper good quality synthetics in all your moving parts, there is no reason why it would break prematuraly under normail maintance.
How do you know that? If you think about it, 150k is not really all that long for a modern engine....I know for a fact that the 3.7L and 4.7L are built to last 150,000 miles....
