Nutzerts
72specialized
Newcastle, On. Canada
Other then Chrysler is there anywhere to get nutzerts?
I bought a set of factory rock rails off a renegade from British Columbia. They don't use road salt there. I called my local Chrysler dealer to get the nutzerts to install the rails and they want $10 a piece for them.(X18) Ya.......NO!
Is there any other place to get em or do I own two lengths of scrap metal?
Thanks,
Alan
VAhlene
Castle Rock, CO
The size you want is M8 x 1.25 I ran into the same issue when I picked up a used set of mopar rock rails that have since been replaced by CRS rails. I was able to find them at a local place in Denver called AAA Metric. However the site Jo6pak listed has them available as well! Good Luck!
jeeptorino68
Oregon
fastenal will also have what you need
however some of the factory holes in the frame like for skid plates are a hex pattern and standard rivetnuts will not work there. mopar only
Jo6pak
Left coast of WI
Yeah, I found that out the hard way. I tried using Fastenal rivet nuts to put on my trans. skid. I held it fine until I removed it a while back to clean the undercarriage. When I tried putting the skid back on they broke loos and just spun around with the bolt. It was a PITA to get them out!!:thumbsdown:
the_dealer
Macon, Ga
Polyperformamce.com, metalcloak, and chassisumlimited.com just to name a few
Sent from my SAMSUNG-SM-G870A using Tapatalk
John3seventeen
WV Panhandle
I used a standard size closest to the metric hole size(had to tap them in) coated them with some locktite and I had the bars on and off several times till I sold them - no problems. Got them from Automotive fastners.
