2005 Liberty TPMS - OBD
Ohio-white-kj
ohio
What, if anything can be displayed with a OBD scanner? I've had 3 dead ones replaced and so far, they have not reset. I've done the drive 10 miles or so 4 times. One was the spare and aware that it needs to set. I have an EVIC, but it only show low and not which tire.
I have not had a chance to return to the tire shop. I'll get there next week, maybe,
So - will any scanners show which ones may be bad or whatever. Or any other tips ? What is the current recommended scanner.
The only thing that sees everything is a DRB III, the old dealer scan tool. A modern Snapon or equivalent may be able to see it but sadly none of the cheap scanners can do anything except the engine.
The cheapest way is to get a garage with a top end scanner to diagnose it.
My Autel 808S-TS does everything.
Does your KJ not tell you the pressures? Does it only have a light that comes on when a tire is low or a sensor is bad?
Ohio-white-kj
ohio
That's a little rich for my blood :) Was hoping one of the Bluetooth ones would do it.
RobDatt
Help with ZEVIC and tire pressure readings also. Mine use to say retrain, but no longer.
