not charging
tomrad
Maryland
My son's 2003 Liberty has the battery light on, and I checked voltage with engine running, 11.5. I'm guessing alternator.
Original alternator, with 125k miles.
I understand the regulator isn't in the alternator?
Looks like the 136 amp one, from the pictures I've seen, the back is gray (160's are black, as far as I know). Any way to tell for sure? I don't see any obvious markings on it.
Now to buy one....any recommendations?
Thanks!
At 125k that is some very good service life form the OEM (Denso ALt)
62316[/ATTACH]"]
The photo shows the part numbers for googling them.
You could even probably find one at a salvage yard.
The PCM controls the charging so the above Denso works fine.
Billwill
White River, South Africa
Check the charging voltage right at the large lug on the alternator....this thick cable going to the positive terminal on the battery actually has a "fusable" link inside it....like a fuse.
There is a remote chance that this fuse may have blown due to a short to engine or while jump starting the engine. Check also that the small connector on the alternator is firmly connected.
With battery disconnected I would also re-plug the connectors on the PCM a few times in case of a dirty connector pin.
The voltage is regulated within the PCM so hence the need to check for a clean connection.
The Battery Icon on the early KJs also comes on if there is a problem with the Battery Temperature Sensor located under the battery but if there was a problem with this temperature sensor you would still expect to get about +13 volts across the battery with engine running.
But yeah probably time for a new alternator!
tomrad
Maryland
Thanks, it was the alternator that failed. Easy to replace on these vehicles. I torqued the bolts as specified in the service manual, however, I just snugged the cable lug. The manual stated 115 in lbs, but I didn't think it needed to be that tight. New alternator has a lockwasher on the stud, unlike the old one.
Thanks again for the advice.
