Hello all, this is my first post and I was hoping someone could help me out. so about a week ago I was getting on the highway and at around 40 mph, all of a sudden, it felt like the transmission was either slipping very badly or popping out of gear. I would hit the accelerator and it was as if the car was in neutral. When I stopped and tried to accelerate again the car would go fine through first gear then when it tried to shift into second it slipped back into neutral. Also reverse does not work, it feels like it does not engage at all. I thought it could maybe be a problem with the transfer case position switch so I replaced that and the codes are still there and the driving problem has not changed. I was wondering what some of you might think the problem is. Thanks a lot for any help and if anymore information is needed please let me know.
Quick Info
2005 Jeep Liberty V6 3.7 L Automatic
Engine Codes P0700, P0837, and P0839
Forward gears slipping, Reverse not engaging at all.
Transfer Case Position Switch replaced and no change noticed.
Quick Info
