no lift but want bigger tires?
coloradored
Colorado
well I'm new to the KJ's but not to jeeps, I just got my self a 04 kj and i just wanted to know what people have had good luck with in tire sizes with out lifting it. i know about the pinch weld so that will not be any problem. oh and i have the stock 16 steel wheels.
I think that the largest tires from the factory were the 235/70/16 but i don't really know that for a fact, and so i was hoping that the 235/85/16 would fit with that pinch weld flattened.
Thanks
jeepkj02
Holland, Michigan, USA
The biggest you can fit is a 245/70 w/o any lift.
With a lift the biggest you can is a 265/75 (32") with the pinch weld pounded down.
235/85's or 265/75's will need alot more then pounding the pinchweld down and a lift(3"+ min lift).
But 245/70's is the largest you can go without a lift,and you may or may not still have rubbing issues,depends on the type of tires used.
coloradored
Colorado
thanks that helps,
does any one know about the speedometer being off after that (245/70/16) or will it be ok?
I've got 245/75/16's on Moabs on a pre-lowered with no lift. Slight rub, I will eventually pound down the pinch welds.
Yep you can get away with the 245/75's if you have a pre-lowered KJ which sits 3/4" higher then the lowered KJ's.I ran that size for awhile before my lift also,only rubbed on the foglamp doors at full lock in reverse.
coloradored
Colorado
does any one have a pix of there jeep with 245/70/16 with no lift that they can put up?
Jeepman56
Green Bay, WI
Here is my '07 with 245/70 General Grabber AT2
coloradored
Colorado
thanks
did you loss much power by going up to that size? and how is the speedometer is it still reading correctly?
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
thanks
It reads pessimistic... you're actually going faster than it will read. I believe the dealer can reprogram the computer... it may be about 1-4 MPH off, depending on speed.
No power loss... since the tires are wider you may lose about half a MPG (Some people lose more, some don't lose any, depends on driving style). That's just what I've observed with the 245/70R16 size.
But on a stock KJ that size looks great! (But it is a tight fit...)
Andynator
Bellefontaine, OH
If you are only wanting a little increase in height WITHOUT a lift, put on a set of 225/75/16's. It's the stock tire size on the Sport models, and slightly taller than the 235/70's. By slightly taller, I mean like between 1/4" to 1/2". The 235/70's were OEM with the off-road package.
Andy
coloradored
Colorado
thanks for all the info i think ill end up with the 245/70/16 but not quite yet, still need to pay off the jeep. lol
nmadd118
LI, NY
jeepman do you have a side view of the kj with the 245/70R16's?
KeswickDave
Gold Moderator
Queensville, Ontario
245/70-16 Revos on here, no lift... very slight rubbing at the front inner fenderwell at full lock but nothing I'm worried about.
The speedometer is only out slightly, reads maybe 2-3 mph low according to my GPS.
And yes, I cheated and posted my photoshopped pic with the painted rims and bedliner'd flares. Hopefully I'll get around to that soon :)
06Liberty
Odenville, AL
my wife's KJ with 245/70R16's..no rubbing, even flexed.
Marlon_JB2
Kombat Edition Jeep
Dave, you're good with Photoshop.
I like the flares, but don't like the wheels... never been a real fan of black wheels on Jeeps.
KeswickDave
Gold Moderator
Thanks Marlon... I wasn't either at first but it's growing on me. I tried it fully painted out and didn't like it, but I like it with the center caps left silver.
Staying on topic, I think the width of the 245's really makes a difference from a front/rear viewpoint as well, looks more agressive.
Jeepman56
Green Bay, WI
I really like the more aggressive look of the Grabbers in the 245/70 size. Here are some pics I dug up really quickly.
Without the rack on yet:
A few months ago:
coloradored
Colorado
so i finely got my new liberty out in some dirt and on some county roads and could not stand how sloppy the 215s were compared to my old jeep with its 31in tires. so i really cant wait tell i can get those 245/70/16. so if any one is looking for some very new Goodyear tires?
ciberbosco
Westchester, NY
I am running on 245/65/17 Firestone Destination A/Ts on 17" Jeep chrome clad Oasis wheels. No rubbing to speak of, and they completely change the look of the vehicle. Not to mention, I enjoy the additional traction and stability of a wider tire...especially in inclement weather. Stock, the tires would chirp when the turbo spooled up and, in the rain traction control came on all the time...not anymore! drive.gif
