new tire/rim questions
MrJ
Florida
running a 3" lift. looking to get some new tires and rims with different backspacing to stick out a little more. any suggestions? i'm new to this, just picked up my kj today. looking to add a front locker (eaton or arb) and do wider tires with a wider stance. thanks guys!
Same as been listed in the forum
7 inch wide rim
4 inches of backspacing
245-75-16 tire
or
265-70-16 same height
above tire and wheel combo will sit the tire at the edge of the flare
Maroon one has the above tire and wheel combo along with 3.75 inches of lift to give you an idea
MrJ
Florida
is there any way to run a bigger tire? was thinking jk rubi takeoffs (just under 32") i have no issue removing fender liner and hammering pinch weld. did it on the WJ. i plan on wheeling moderately. what do you suggest?
32 inch tire/ 4 inches of lift/ 4.10 gears
JK wheels won't work, different bolt pattern
should hammer the pinch weld anyways, removing liner doesn't gain you that much in reality
dude1116
Pompton Plains, NJ
JK wheels are a different bolt pattern. You'd need wheel spacers/adapters.
