Billwill
#34 is the problem inside the car.
I am just jumping it off each morning.
Any help on seeing what #34 interior fuse affect? wiring diargrams flew slightly over my head. I believe it is radio, dome lights, tag light, locks and power mirrors, tailgate - what else
sitting measures 12.8
Key on measures 10.4
Key turned (rapid clicking) drops to 9.5
Here is the wiring diagram 8W-12-32 for the 2005 KJ. You can download the complete 2005 KJ Service Manual here...includes all these wiring diagrams:
http://www.colorado4wheel.com/manuals/Jeep/KJ
These are all the components being supplied by Fuse 34 (15 A) on the internal Fuse Panel (Junction Block).
You will not have all these components in your Jeep...some are for Export Models or maybe for Premium (full options)
You could have a short somewhere or something like the radio may be staying ON after ignition is switched OFF.
You will see that all these wires are labeled as RD ie. Red. and the fuse output goes directly to the BCM on the rear of the Junction Block and also to the other components via pins 27, 15, 14, 30 and 18 on Connectors C1, C2 and C3 on the Junction block and pin 15 on the JB connector of the BCM...if the connectors are not labeled then look for the Red wires coming out of them and check the Service Manual, 8W Wiring, Junction Block 8W-12-2 for the connector locations.
Unless you have the correct Pin Extractor for these types of connectors you will not be able to remove a pin to eliminate which path is causing the power drain.
So you will have to cut the wire a few inches from the connector. For example...cut the Red wire coming off Connector C2 Pin 18....this cuts off power going to the Radio, Dome Lamp... if you have the base model...and the compass mini trip, cargo lamp, right visor vanity lamp, left visor vanity lamp, hands free module, Overhead map etc. if you have the "Except Base" model. If the current draw is still high then you know that this is not the path causing the current draw. Slip some Heat-shrink insulation over the wire that you have just cut, solder the wires back together, slip the heat shrink insulation over the joint and heat up the insulation with a hair dryer to shrink it for perfect insulation.
Then repeat the process for all the other Red wires coming off the connectors...it will always be the last one available!
Lots of work but you do not have much choice if you are sure that Fuse # 34 on the Junction Block is the cause of the high current draw. You could first disconnect the radio connector, instrument panel connector etc. to isolate a bad component but this does not rule out the wire going to the component chafing to chassis hence the need to cut the wires right at their source on the Junction Block.
