kchawda
Hello y’all,
I have a maddening issue currently and this seems like the place to find direction.
1st – 05 Liberty 3.7 2WD – 189,000 miles
When even I travel over 70 for extended amounts of time the engine light comes on. After 3-5 starts through the light goes out (A lot of traveling in it – get off highway get gas, get a bite to eat, visit a local attraction – light out). The vehicle never did anything crazy or out of the ordinary (I would know – I’ve had it since it had 13 miles). Last week I noticed a rattle that went away when I hit the gas until the vehicle warmed up a little (1-3 minutes). Also in the evenings when starting it there was a high pitched whirl for a moment or two.
Battery is newish (6 months) – tested good recently
Alternator is good – bench tested and tested on vehicle
Swapped around all the fuses (40 amps) related to ignition or starting.
The car is dead as possible in the mornings now. It has to sit on jumper cables for 10+ minutes. I feel as though there is something loose but visually checking and pushing/pulling has netted nothing. Any common themes you all have experienced? I currently do not have a tester, but certainly will get one if need be. I saw the advice on removing the negative cable and hooking up the positive and check to verify there is anything showing when it shouldn’t be. It seems the cigarette lighter/charger port is common, but would not line up with other existing possible symptoms.
I promise I will not be a ask-hole and will act on the feedback!
