New 06 Renegade Owner w/ Tire Questions
RenegadeBullitt
Willow Spring, NC
I have searched but I cant really find exactly what I am looking for. My question is, if I get a 2.5" lift and I get some 31X10.5 tires will I need to run wheel spacers or anything on my stock Renegade 5 spoke wheels?
Most run a 245-75-16 ( actually a 30.5 inch tall tire) with a 2.5 to 3 inch lift. Depending on the tires ( tread pattern etc) you may not have any problems,BUT You may have to pound over the pinch weld at the rear of the front tires and possibly trim some of the front bumper at the lower part
Also depends on what lift you are getting, for example an 06 with a Daystar then possibly more problems, or say a Frankenlift then no problems
so we need to know what type of lift and what type of tires to give you a more educated answer
Welcome to ...mmm had to look where I was KJC!!!
boebr1
Helena Montana
avoid running spacers... more likely to rub. at full turn it's put the shoulder of your tire closer to the pinch weld, and on the rear at articulation, the shoulder of the tire will be just that much more into your flares. oh, and 90% or more of tire or mechanic shops will not do any tire or suspension work on your rig if you have spacers... insurance reasons...
RenegadeBullitt
Willow Spring, NC
Thanks guys. I plan on going with the OME lift here in a few weeks with some new tires but I did not want to have to change my rims.
