Need help
mxtapltz
I have a 2005 KJ limited and once and a while the left side running lights as well as the rear signal light stay on, also the dash left signla indicator stays on. I traced the wires and they are good if I shut the KJ off and restart it goes away for a while I know it seems their is a ground but it is intermittent the only way I have found to correct this is to pull the DRL relay, has anyone encountered this before? Thanx for any help
If it is intermittant, it sounds like a loose/bad ground. I am not good with wireing, but I just gave you a free bump. The KJ's in the US do not have DRL option that I know of. Maybe someone that knows more will see this.
mxtapltz
Question
If you don't want DRL's can you just put in a high beam relay? if so what is the relay part #? My fuse box by the driver side door has a spot fir a relay but the configuration is different than the DRL relay. Thanx
Staff online
