need help asap!
6ixJeeper
Toronto Ontario Canada
i have a 2006 liberty and i want to know what power steering fluid i need to top it up, im thinking the mopar one. Also is there a diagram for the fluid's in the engine bay? because im not sure what a couple of them are. Theres no vehicle info guide because the previous owner took it.
ATF+4, any brand is good. All the same license. It’s the reservoir near the alternator
turblediesel
memberable
Alaska
Check in your glovebox for the manual; there's a slot on top inside where it's stashed. Easily overlooked, or just not there.
Billwill
White River, South Africa
Definitely ATF +4 for your Jeep.
The 2002 KJs came out with Mopar Power Steering fluid which is a light yellow.
There was a TSB issued that Mopar Fluid and ATF +4 must not be mixed and early 2002 KJs should have the fluid drained, the system flushed and fluid replaced with ATF +4 at the Dealers.
I have recently bought about 2 Litres of Mopar Power Steering fluid for my 2002 Export CRD as it was never converted to ATF.....I do not trust these Local Dealers do get this conversion right...they are sure to screw something up!
What I do is suck out as much fluid as I can from the Reservoir using a large syringe and tubing....fill it up to the correct Cold Level and repeat in about a years time!
Welcome to the forum.
You can download your 2006 owners manual here: https://carmanuals2.com/get/jeep-liberty-2006-owner-s-manual-31126
If you are having to top up the ATF+4 power steering fluid, search for a leak on PS lines & around pump.
Once a year I suction out the Atf+4 to keep it clean.
A small funnel ready to add the Atf+4
You can see the Cold & Hot lines on the tank.
that's wild to see the pump on the wrong side. :D
