My Clevis
thekjwith9lives
Pasadena,TX
I was wondering if you people could tell me if this clevis on my KJ ,that i bought used, is stock or not? The pictures i see on here are different than what i have.This kind of looks like the Rock Krawler lift but im not sure.The KJ is defiantly lifted when compared to stock ones.Any help would be appreciated!
thekjwith9lives
Pasadena,TX
Ok and its a 2005 i was wondering if they changed the design any but i guess not.So if i want to do the OME lift would i have any problems with those aftermarket clevis's?I plan on doing the OME lift in the near future.
Yup, I agree with Corwyyn.
Check the bolts to be sure they are graded on the bolt heads.
thekjwith9lives
Pasadena,TX
Would i run into any problems if i wanted to put the OME lift on in the future or would i have to get stock clevis and put on?
Diggerfreek
Colorado
you would have to get the cut down cv's and probably the ball joint extendo thingy jeepin by al uses
With the OME + the rack crawler, that almost 6 inches of lift
thekjwith9lives
Pasadena,TX
Im not sure whats on the rear it seems like the Rock Krawler lift has a spacer for the rear if im not mistaking.I bought it used and just found out it has the Rock Krawler X Factor lift on it:eek:The lift has been on here for some time from the looks of the clevis ,but it drives fine and I've taken it wheeling through some bad stuff and nothing suspension wise has went wrong.
thekjwith9lives
Pasadena,TX
Ok that's good to know but i just put some Rancho's all around it a couple of weeks ago and i could tell someone has been in the front end on it,I knew its been lifted but i just didn't know what was on it.Thanks for the help and ill make sure to trash these things as soon as i get the OME lift because i see where people have bad reviews of this lift.
tour96se
or you could send it my way;)
