metalmoto
OK, I put a brand new exhaust system on my "02" from the "Y" pipe back.
The "02" has since dropped a valve, and ruined the engine. So I am trying to reuse some of the "new" parts from my "02" and put them on my new "04".
I've found that many, but not all parts, will fit and work on my "04".
The exhaust system is different, on the "04", especially the catalytic converters, and the front "Y" pipe. But I am hoping to at least re-use the "new" muffler and tailpipe section. As these parts look the same. The exhaust was only on my "02" for a month or two, before the engine blew.
The tailpipe was inserted into the muffler, and just clamped on. In that short time, the clamp got so rusted, it took me about an hour to get it off.
Anyway, now I got the clamp off. I can't separate the muffler from the tailpipe.
It would make it a whole lot easier to install on my "04" if I could get the dam thing apart. Someone said to heat up the pipe with a torch, but all I have is a propane torch. Not sure if that would get it hot enough to expand it.
Anyway, does anyone know if I can even use the muffler and tail pipe from my "02" of my "04"?
I doubt that the new front "Y" pipe will be of any use. Too bad, because it was expensive, and has the third cat converter in it...
I wish I had some pictures of the different exhausts, to see if I can re-use "any" parts of it.
Anyone have any info, ideas or suggestions? Need to fix the "04" exhaust, as it has some leaks, I can hear it popping, when I let off the gas pedal.
I can't afford to buy a whole new exhaust system for my "04" and trying to re-use these new parts.
Please help!
Please help!
