Lower control arm bolts stuck
Jaybird91
So cal
Help, Im having trouble getting the front lower control arm off. The cam bolts seem to be stuck with the inside of the bushings . Any suggestions. I tried a reciprocating saw but it doesn’t seem to work.
Can you apply heat with a torch? Maybe that would burn out the rubber bushing too though.
Royy
Western CO
Reciprocating saws usually are the best ways to get those bolts out if they're seized. But you need a good high-quality blade.
The first time I had to cut one of those bolts I started with a cheap blade from Harbor Freight. After half an hour, it still had barely made a dent in the bolt. Got a better blade, and it went through the whole bolt in a couple of minutes.
Jaybird91
So cal
Finally got those bolts off. I used a carbide blade and it work . Thanks all for helping
