loud "hummig" & "rumbling" noises
arielflash
Israel
Hi,
Ever since i got my libby there is a pretty loud humming sound when as speed goes up - some people say it sounds like a bad bearing (which one??)...
Already replaced tires, both front hub assemblies, passenger side CV, front and rear driveshafts reman... whats the next thing i should check ?
Also, theres a noticeable "rumbling" noise sounds like coming from front starting at ~25-30 mph... sounds like its coming right behind the dashboard but I couldn't see any loose parts inside when taking the radio off and having a look... any thoughts ??
I can also feel some vibrations going ~50+ mph (event after having both rear & front shafts remanned) - not sure if its related to any of the other noises...
Isn't there a proper way to locate where exactly noises are coming from? :\
Thanks !
Lancer
South East London
The only way is to drive it with someone else with you, who can move around inside the vehicle to localise the sound's origin. That person should be a mechanic, so that they are in with a chance of correctly identifying the problem.
Just to be a pain, could be that the pinion in the diff is on its way out. When mine started going a couple of years ago in Germany, it made what I described as a low howling as I accelerated and remained at a low level as I drove. It was diagnosed by a very good Jeep mechanic in Wurzburg who climbed around inside as I drove in the manner described above. Cost me £2000 to get rebuilt when we got back to England.
