This is a KJ subject
Why are some liftkits not suitable for a Diesel(CRD) cherokee.
I have a 2006 cherokee crd and want to lift is 2 inches. Can anyone give me info about the options
Thanks in advance
E vd Berg
Holland
First of all, your question belongs in the KJ section, not the KK section.
Being KJ-owner and Dutchman myself (but living in France), I feel obliged to help you out.
Some kits are not suitable for the CRD, simply because the diesel engine is heavier.
I had first a Skyjacker kit installed, which turned out to be a disaster. I now have a setup, which is perfect. Go for the OME shock's, they are unbeatable. Part numbers: front OME NS131, aft OME N132.
For springs, I prefer King Springs, front KJFR-27HD, aft KJRR-28. (The CRD needs the HD heavy duty springs upfront). This will give you some 45 mm of lift. (
www.kingsprings.com)
You can also use OME springs (which happen to be made also by King Springs), front OME 927 (=HD), aft OME 947 (=Medium) or OME 948 (=HD); choice of rear spring is a matter of personal preference, whether you regularly heavily load your vehicle, or pull heavy trailer, or not.
Note: Do not use the OME 790 CRD springs upfront, unless you have a heavy ARB bumper and/or winch upfront. These springs are too stiff for regular use on the CRD.
