Selwyn
Hi Guys
Here's what this thread is about:
My Questions (please remember this is CRD territory!):
How do I obtain maximum lift without touching the inner CV joint boot?
How do I protect the CV joint at full droop?
How do I maintain maximum suspension travel, no limiting straps!
Are the different makes of shocks for the KJ front end exactly the same length, OME included?
This makes everything equal the same suspension travel irrespective of shock make.
Tony makes mention of this same issue in the post, lets find the best solution, make this issue a new topic open for discussion, allow radical ideas, somewhere we will find an answer.
Just to get the ball rolling: -
“Cramp” the coil over into the space available above the CV joint boot, allow full movement of the coil over.
Do all the lifting modifications below the coil over.
Fabricate an adjustable clevis.
Fabricate a new LCA if necessary.
Fabricate a new mounting point for the Clevis on the existing LCA.
Anything is possible if we hunt for solutions!
Regards
Selwyn
Regards
Selwyn
