Remove the hose going into the PCV and clean it or replace it. (should rattle)
Turn counter clockwise to remove it.
They can look a "little" plugged sometimes..
53191[/ATTACH]"]
I dont know if your's has the oil baffle inside the oil filler tube, remove it and make sure it is clean inside as well.
53193[/ATTACH]"]
53195[/ATTACH]"]
That cord is the block heater, you should tie it up along the L fender side, away from hot zone.
Mine is tied up here, & I used an extension to outside the grille.
53197[/ATTACH]"]
Power wash under the hood well, it will be easier to see leaks.
Replace the valve cover gaskets if they are leaking.
I recently power washed,& only covered up the alternator, and that was about it, and let er have it.
Looks ok now..
53199[/ATTACH]"]
