themadness
FIRST POST!!
i know the p0122 is the tps and i will most likely replace it myself but i need a few details on the change.
i read that the sensor has to be tightened to a certain measure. how do i know how tight is too tight for the screws when re installing it.
what is safe to spray on the screws to loosen them up before i remove the sensor. i dont want to strip them and/or damage any electrical connection.
should i clean the throttle body first or just bite it and replace the sensor?
is it possible to clean the harness to avoid breaking a brittle connector with out damaging any electrical components?
am i missing anything? i know it should be simple but i dont want to run into any dumb mistakes and make the change run as smooth as possible.
:doh2:
:doh2:
