KJ Rear Turn Signal Socket
KF4GL
FL
Hello,
I need to find a rear turn signal socket for my 06 Liberty Sport.
This socket is different than the break and backup light socket.
The socket for the bulb and the leads are different.
Does anyone know of a source for the correct part?
Thank you
Probably best to give a dealer a call (parts department) on that one.
Even if I posted the parts fishe it is outdated now.
Once you have the correct dealer part # which is known to be the correct part, you can then do a cross reference check on the net if ya care to go after market.
It is still best to use factory parts & this one should not be that expensive.
KF4GL
FL
Thank you. The part is not listed on the Mopar sites I have been checking. After market sites only lost the brake/backup sockets and "suggest" that they will work for the turn signal. However the sockets use different bulbs with different plastic guides on the sides.
KF4GL
FL
Dealer part number is 55157302-AA. My local dealer will have it tomorrow for $16.00 Autozone online had a similar part for $26 plus shipping.
