kj lift
Discussion in 'Lift Kit Discussion' started by GregR, Jan 31, 2020.
  1. GregR
    GregR New Member
    Jun 2, 2019
    So i finally decided to lift the kj and im in information overload from scrubbing through threads i am in between on the ome hd and medium and not sure if i should go with ome or bilstein. I primarily use the jeep as a daily driver but also use on the property for hauling trailers and dragging the occasional tree out of the woods. What im looking for is a comfortable ride for the wife with the capability for some heavy loads and more clearance.
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,781
    415
    927/948 springs
    shocks depends on what you like bilstein or OME
    both ride about the same
    nothing hard on coming up with what you want
  3. GregR
    GregR New Member
    Jun 2, 2019
    With that being said is the brake line relocation needed with this lift?
  4. tommudd
    17,781
    415
    Well, if we knew what year you have it would help to answer this question, up to 05 no, 06-07 yes , easy to make, takes two minutes
    if you are going this route we can provide what shocks to look for
  5. GregR
    GregR New Member
    Jun 2, 2019
    So i have a 05 limited and i am looking at the following:
    Bilstein 24-139168 front
    Bilstein 24-185660 rear
    ARB 2927 front
    ARB 2948 rear
    As found on another thread, was going to go through jba but everything seems to be out of stock. Found everything on Amazon so far the only thing im unsure of now is the correct part numbers for front and rear bump stops, as far as ive read they are needed to prevent stacking of the coils.
  6. GregR
    GregR New Member
    Jun 2, 2019
    I found the front bump stops now i just need the rear i have seen the 2 hockey puck method but wanted something with a bit more give. Also should i replace the rear upper one while im at it?
  7. duderz7
    duderz7 Full Access Member
    326
    60
    Jan 20, 2016
    Weiser, ID
    Unless the stock rest bump stop is worn or falling apart leave it in place and add the hockey pucks. That way you retain the stock bottom out squish but just move it in the proper place to work with the lift.
    tommudd likes this.
  8. tommudd
    17,781
    415
    Trust us, the hockey pucks are what you want and need, they do not, DO NOT have to have more give, you DO NOT want them to have more give even !!
