kj front axles noises
ronsjeep
nanaimo
hi just joined this form found it quite use full ,just had problem with noises from front right passenger side after alot of searching found that the front splines that connect to front end housing to the axle was totally rusted together made clunking noise an is probably alot of other peoples problems check this out if cv joints an other things seem to be ok there are no seals on this an should be greased was weird that this is so open to this ,,,
Not an uncommon problem and an easy fix Thank goodness!
New Intermediate shaft and rebuilt CV from NAPA and you're good to go
