Bp.designs
Hey all! So here's the low down... I just finished putting everything back together on my wife's 2002 liberty sport. It's getting spark to both banks and fuel as well. When I tore the engine apart I did not replace any of the timing chains. Before removing any cams I sent everything to top dead center by aligning TDC mark with the notch on the crank pulley and then making sure both cam shaft gear V-6 marks were at 12 o'clock. I then put a screw driver in the cylinder 1 intake and rotated the crank 2 times around watching the screwdriver rise completely, drop and then rise again to ensure TDC. After removing both cams I did not touch the crank . When I put everything back together I made sure the cam gears were set with the V-6 mark at 12 once again and the crank was still at TDC Mark. I then rotated the crank a full cycle (2 times) and repeated at least 5 cycles to ensure the timing V-6 marks always came to 12 at the same time. I believe the timing was set up correctly but I can't think of anything else that would keep it from running . Any kind of help would be greatly appreciated. Thank you
