JK Flexing
06Liberty
Odenville, AL
Only had about an hour today to play around, so nothing special...just haven't had time to really flex it out since I added the extra spacers up front, so I wanted to make sure everything was OK. :D
06Liberty
Odenville, AL
That is good flex. Stock shocks?
Yep, shocks from a Rubicon actually but same difference...but I've got some shock extensions on the front shocks because I added 3/4" spacers up there to give the front 2.5" of lift and without the extensions it was really limiting the droop.:D
06Liberty
Odenville, AL
I've never heard of this before.
They mount on top of the shock, just essentially makes the shock longer so that you don't lose any downtravel when adding a lift. Usually when you add a lift, you add longer shocks also...but on alot of the "budget boost" lifts, they include shock extensions to basically achieve the same thing. This way, you don't lose any articulation.
J-Thompson
just south of doucheville
I hope you extended your bump stops
if not the shocks will be shot shortly
06Liberty
Odenville, AL
Nice pic's......nice jeep. Love those power line roads.
