Jeep Wrangler Canyon Wheels
02blujpx
Quick Question...Can I run the stock TJ canyon wheels and tires on my wife's stock 04 liberty?
Wheel size is 15x8 with 5" backspacing
Tire size is a 30x9.5
Thanks for all the help,
Chris
Nope, they will rub bad. Just got some rims on my jeep that size with 5" BS and Im going to shoot myself they rub so bad.
jfortier777
Detroit, MI area
Chris
Also, even more importantly. You wont be able to fit them over the calipers.
To date, the only 15" rims that fit the Libertys are the Rock crawler 15".
jfortier777
Detroit, MI area
You bought 16" cragars didnt you? I could have sworn you did.
I have full turn no rubbing to the right side, and 90% turn to the left with my 265s on the 16X8 cragars
Eddo
USA
I have Rubicon rims 16x8 5" backspacing, with 245/75/16 MTRs mounted and they only run a tad at full lock.
The fronts barely rub, the rear is what I working on to try and fix. I need to get some bumpstops, they rub when flexed. I only have a 1.5in lift also.
Do you have the franken lift bumpstops on the rear eddo? I was looking at some of your pics from slade and your tires are stuffed in you wheel wells. Im hoping those will stop the rubbing in the rear.
jfortier777
Detroit, MI area
Gotcha, that makes sense.
