Re: Sorry bout that
indieaz said:
Well, a knock sensor is used to detect knock
Exactly, pinging, knock, predetonation, whatever you want to call it. I'm still confused on how a crank position sensor would be used to detect misfires. Unless you mean the computer is comparing distributor/coil firing in relation to which piston should be at the proper position at any given moment when that particular plug fires. I guess if it didn't detect a fire on a cylinder and catches that that cylinder should've fired by looking at the position of the crankshaft to determine that it was in the spot it needed to be in when it was supposed to have ignition. Is that what you mean? I'm not calling BS on you or anything, just trying to figure out what you mean, I'm all about learning. #-o
Here's an example.
The crankshaft is rotating and cylinder #1 rises to it point where ignition is supposed to take place. The distributor doesn't send a fire to spark plug #1(or it does but the spark plug is bad or whatever). The computer catches that a misfire took place by looking at the location of the crankshaft and determines that ignition should've taken place at the point. Is that what you mean?
I guess we're a little off topic...anyways, like I said, not causing trouble, just curious.
