Cpt Marvel
Once in a while more than a tad. But usually just a little. Smells like oil. I did a compression test on it. First crank, ALL of the cylinders jumped up to 150 and then to dropped to 120, by the 5th-7th crank they were all at 180. Did the wet test and no change. All the plugs looked good except two insulators were slightly darker than the others. Plugs have about 1,600 miles on them. Slight bit of heat glazing. No knocks, rattles, pings or chatters. Engine runs so smooth that sometimes I have to check the tach to make sure its running. I do have codes for bank 2 O2 sensors, which I am going to go work on changing right now, with NTK replacements. Could bad O2 sensors cause the engine to smoke by making it run rich? I guess I'll find out. Putting a pic of the plugs in.
