JBA 4inch lift
sydbro
Sykesville Md
Looking for any one who has the JBA 4 inch lift and any thoughts you might have. I currently have the 2.5 frankenlift.
If you have the Frankenlift unless very old its 3.5 inches or so, yes advertised at 2.5 but all of the ones I have installed were 4 inches and above when installed . What height are you measured from middle of the wheel to bottom of the flare on the right front?
To go 4 inches you must go with the JBA coilovers / JBA UCAs etc
Plus then have issues with the CVs at that height, regear of course since you'll want larger tires . Not cheap.
Just so you know. I have about 100,000 miles of experience in running 4 inches and above so lets hear your questions
sydbro
Sykesville Md
Right now I'm at 21.5. The lift is 8 years old but only about 5k miles on it. I understand that I will need to cut the CVs. From what I can tell the JBA kit comes with coil overs. The main question I have is it worth it compared to what I have now?
No comparison between the two,
For example going from crappy stock suspension to OME improves the ride and handling a bunch, going to the JBA coilover lift is ten times over that. Ride and handling is unbelievable, no matter on or off road.
I never ran cut CVs, just used NAPA remanned ones , main issue is the boots rubbing together at those angles and then have to replace boots of CVs especially the right side .
Ran JBA 4 inch on the 04 and when I got ready to buy the 03 I had already bought the 2.5 inch coilover kit with adjustable rear shocks as well before I actually bought it. I knew that is the only way I would be satisfied with it ride and handling wise.
Are you regeared already ?
Tommudd's Econo 3.5" Lift Kit
would you suggest this 3.5 over the 2.5 platinum package with the fox shox? regardless of the price?
Again , two different lifts completely
both lift, but like I explained above the JBA coilovers exceed the OME coils as far as ride and handling.
While the OMEs give a great ride and most all of what I install here, just a different type of ride with the adjustable coilovers
sydbro
Sykesville Md
Ive only put a spoller/Richmond locker in the rear...no gear change...I think it's stock at 3.53..not sure. Would I need to go with 4 .10 for a half inch? I don't plan on changing tire size. If you look at some of my pics...that's what I'm still running
sydbro
Sykesville Md
I plan on keeping my kj....just want to know if JBA lift is worth the cash...it's not a daily driver... only off road a handful of times a year....just want to keep up with my brothers Wrangler....and I push snow in my driveway with her
sydbro
Sykesville Md
From what I have already....would it be worth the money for JBA 4inch?.....that is my question
What size tires are you running ??
If automatic you have 3.73s
If you only drive it a few times a year keep what you have
going from 2.5 inches to 4 inches of lift will not make a huge difference , I mean a small amount but , if you off roaded a lot, drove it a lot then sure the JBA would totally be worth it
kejobe
NE Ohio
If I remember correctly, 3.73 is stock for 6 cyl. gas, 4.10 for 4 cyl. gas, and not sure about the CRD.
Myke
USA
I have the 4 inch jba lift. I really like it but it's a daily driver 5 days a week and offroad one day a week and I beat the crap out of it.
I keep up with my friends on 35s/37s no problem.
I love the adjustability. I can make it right great on the street and then turn 2 knobs and adjust it for the terrain I'm doing.
If I wanna pretend I'm in Baja prerunning I can firm up the compression. If I wanna ride like a Cadillac I can turn it down.
I just wish I went with the fox shocks as they are valved progressively vs the bilsteans degressive valving.
I do get noise from them if I turn up my rebound over setting #9 while offroad. I believe it's the oil going through the valve and makes a squeekish noise.
