JBA 4" lift...new CV joints?
madeuce22
Long Island, New York
I've been looking at the JBA 4' lift and see the package doesnt come with new CV joints, yet the rockfather lift says the kk cant go over 3' without having binding in the cv joints.
Any thoughts?
and yeah im new to this...
Any thoughts?
FIRST thing
back away from the computer until RRO and Rockfather is gone, do not access their site again and life will be much better for all
STW
California
Google it. RRO = junk
I have the JBA 2.5" lift and love it. Well worth the money
And yes you will need cut down CV's for the 4" lift
S
S
Funny:happy175:
been running over 4 inches of lift for over 100,000 miles
and have NAPA remanned CVs with no issues
Cardhu
Great White North
i think i saw the words custom and ultimate, bout 1000 dollars a piece.
to the OP.
if your lifted too high your cv's will "rumble" a little. And if you bastardize a couple, their pretty cheap at napa in the US. drop it down a bit and try again. I think the magic number is>23.25 inches fender wheel center distance. This could also be expressed as greater then 4 inches of lift.
In all likelihood, you won't surpass the height of top plate, 927, 3 clevis combo for the front with the jba 4 inch (about the same height +- .25") and custom anything won't be needed.
But its your money.
i'm running just a top plate on 927 and i'm at the same height as the last JBA4 that posted heights on here. Still running factory CVs a year later.
TwoBobsKJ
Northern Ohio
To the OP:
You can do an OME/Bilstein lift (advertised at 1.5 inches but actually gives you more) and with a couple of accessories you'll get near 4 inches of lift. Add JBA's 1/4" top plate in the front, 3 conduit nuts on the bottom of the shock above the clevis, and a couple of rear isolators in the back and you're sitting nearly 4" higher than stock. CV's will be fine as others have indicated.
Keep asking questions - that's how you learn!
TO THE OP:
OK here's an update
My left side CV is starting to make noise,..... darn cheap Jeep parts :favorites68:
Its only lasted 177,700 miles of which over 156,000 have been lifted !
and as most will tell you higher than it should be :whip::icon_twisted:
madeuce22
wow thanks alot guys, and i have looked into doing the OME lift with the accessories such as bumpstops and isos and a clevis lift up front and dont see myself even thinking of the expensive JBA anymore.
Youve all helped me and my wallet alot
Honduras
Honduras
I have the JBA 6" with a set of the RCV front and rear axles on order. Pricey, yes, but I'd rather have the peace of mind knowing that my front CVs are no longer the weak point when I'm an hour out from civilization.
My tie rod angles are what keep me awake at night. Still a hundred times more portable than a spare axle set and a pretty quick install to boot. Looking at doing some custom tie rod ends using a set of female heim joints and extensions.
Edit: Just realized that this post was supposed to be a reply in a different thread about RCVs. Sorry for the seeming randomness of it all!
Ry' N Jen
I hope all the top end parts work out for you on your KJ.
But at the end of the day it's still just a Dana 30 up front with minimal flex
IFS off road system.
You do have a very sweet Off Road Rig dude!
