Is Your Oil Fill Cap Difficult To Remove?
Mine often seems welded in place...It wont budge cold...
49329[/ATTACH]"]
I got it off only once things really warmed up after driving a while....
Would anti seize be best to lube the threads..??
I sometimes use channel locks on mine. Usually take some old oil and wipe the threads down though, that seems to help.
mightybeet
connecticut
mine had a disc in there but now its gone. think last place i went took it out. anyone else have that disc? is it required? i use one of those rubber strap grip things to take the cap off.
Porkchop
Troy Mi
I like that it is and I just use the strap on my purse as a strap wrench works every time. I only hit things with my purse when I need a hammer. Right tool for the right job learn to use your purse properly guys and don't abuse your tool.
49331[/ATTACH]"]
Best $7 I ever spent for work,some of those are on there tight.
Save on Lisle 34000 at ToolTopia.com
Counting My Blessings
Can't get an oil cap off? :whymewhyme:
Ok I think I found out why the Cap was so Tight..The rubber ring on the top was bone dry.
So were the threads, I fixed that by...
49334[/ATTACH]"]
Oh it turns so easily now!!
I cleaned/coated the Battery terminals while I was there as well.
49336[/ATTACH]"]
Thanks for the oil cap removal tool linik/reminder Troy!
I also found that Snap On has an Oil Cap tool as well for 2000 & newer.
49338[/ATTACH]"]
However, I don't think a tool will be required anymore....:cheers:
There are SO many one-liners about Vaseline and oil caps just sitting here dying to be let out to play...!! :happy175::happy175::happy175:
CactusJacked
Chicago Suburbs
Can't get the cap off, ya bunch of no good limp-wristed..... ;)
You guys need to visit more **** sites, at least one hand then will be stronger and well conditioned! lmao
02blue
49370[/ATTACH]"]
Real men use axle grease. :rotflmao:
