Is my Jeep Lifted?
OmarKJ
PA
Hello everyone, I bought my jeep last year from an auction it's a 04 limited edtion. I changed the transmission and it's running alright I have always wondered is my jeep somehow lifted? I mean it looks higher than a stock KJ but I don't see any lift kits installed. When I bought it came with 245/75/r16 tires which are not the stock tires so I went ahead and got 4 brand new 245/75/r16 bfgoodrich tires I don't see or feel any signs of the tires rubbing and it drives so smooth, I'll leave some pictures.
Samsolo49
Washington
I would say it has a 1.5 lift at least, I have that same tire size in the all terrain ta and that's how much lift I have.
Sent from my XT1650 using Tapatalk
OmarKJ
PA
I was thinking about buying the rough country 3 inch suspension kit but I have read a lot of complaints about it. Do you know about any good trusted lift kits out there?
Samsolo49
Washington
I have the old man emu 1.5", it rides awesome. They are pretty expensive, but a lot of people on here love jeepin by Al, they make some apparently good kits and are kind of proud of them.lol check out the website jeepinbyal
Samsolo49
Washington
And yes I've read bad things about the rough country lift too. I just try and stay away from spacer lifts
You have a spacer lift, you can see the spacers in the pic of it on the rack.
Tons of threads on here about lifts, take an hour and just read though. You'll be off to enjoying your Jeep so much more. That ride has to be pretty rough.
rjkj2005
US
Measure from the center of the wheel to the bottom of the fender flares. Factory is 19 inches. If more your lifted. If less your sagging and no lift.
You have a small lift, more than likely with springs that are sagged and too large of a tire for that amount of lift. Well of course could install a large amount of bumpstop but
You need a complete new suspension , no junk spacers etc
New springs and shocks front and rear
What springs did you get ? Only OME with 1.5 inches is the 926 front and 947 rear, i are those what you ended up with ?
Samsolo49
Washington
It's the heavy duty springs in the front and the medium duty springs in the rear. I don't remember what number they were. Rides awesome though
IF HDs they are 927s which should have given you 2.5 inches of lift NOT 1.5 inches At least the 50 plus I've installed have always given that much.
Why did you go with 947s in the rear ?
Just curious is all
Samsolo49
Washington
They had standard rate springs but got the ones rated heavy duty front medium duty in the rear. The struts were a pain in the ass, I had to make a fixture so I could put them in a shop press because the thick coils and not much space between them for the normal spring compressor. Rear was a lot easier.
Yes realize how they are to compress the "coilovers" , have done 54 KJ lifts not including my own ( 04 was torn down several times testing various combinations , 03 only one time )
Samsolo49
Washington
Well I ordered and had to wait for the heavy duty front springs and after it was done I'm figuring just under 2", and I got the medium duty springs for the rear so I could mount a rooftop tent and still be able to tow something if needed
Whats the measurements ( middle of the wheel to bottom of the flare in front )
You should be at 21.5 inches with those springs
OmarKJ
PA
As much as I love my jeep I can't afford an expensive lift kit right now, so do you guys think I'd be better off with the rough country lift kit rather than the spacer lift kit I have on my jeep?
OMG, rough country is the worst , it is a spacer lift, not really a lift at all
Only true lift is a full spring replacement with new shocks . Anything else is a pure waste of money.
Now you may think I'm mean, nasty, an a**hole, whatever , But after 40 plus years of suspension work, lifting many over the years and 13 years lifting KJs, I've seen what spacer lifts do
