iron man lift 2007 jeep liberty help
Discussion in 'Lift Kit Discussion' started by Jason Davis, Jul 22, 2020.
  1. Jason Davis
    Jason Davis New Member
    Jul 22, 2020
    upload_2020-7-22_13-50-1.png will this lift be ok for my kids Jeep. He only want bigger tires and goes to the Mt skiing no heavy wheeling. seems complete and cheaper then the OME stuff? and are the rear shocks long enough. Thank for the help. JD
    [​IMG]
    Nitro Gas 2" Suspension Kit - Performance Load (0-440LBS) Fits a Jeep Cherokee / Liberty KJ Diesel
    $639.00
    Ironman 4x4
    Free shipping, no tax
  2. tommudd
    tommudd Moderator Staff Member Moderator
    17,951
    477
    I PERSONALLY TESTED THE VERY FIRST IRONMAN LIFT THAT WAS IMPORTED INTO THE USA BACK SEVERAL YEARS AGO
    WHOOPS SORRY CAPS ON
    While it rode well , shocks felt good etc It did not give the lift you should have, I even used the extras they have
    I did install it on a friends KJ after a while and he had it on for 5-6 years before trading the KJ off
    Its an OK lift, not what I would recommend
    You maybe able to go up to 255-70-16s , 30 inch tire but not much more
  3. Jason Davis
    Jul 22, 2020
    Ok Thanks, I am just trying to find something better then a spacer lift for the kid on a budget.
    The lift below is the only other one I can find but is $461 more with shipping. So the Iron man will work fine for a little lift and a wheel and tire upgrade?
    2002-07 KJ GAS models
    ~1.5" to ~2" OME Lift Kit: $996.89
    This kit is un-assembled & includes:
    OME H/D 90009 Sport Front Struts
    OME948 H/D Rear Springs
    OME927 H/D Front Springs
    OME132L Rear Long Travel Shocks
    Extended Rear Bumpstops
  4. tommudd
    17,951
    477
    Cheap is expensive in the end, even if I have to save up longer than I want to, I try and get the best that I can. Pays in the end every time.
  5. Jason Davis
    Jul 22, 2020
    I would like to avoid any problems for sure with the kids ride. So you are saying the OME lift is that much better? I guess I will take another look. Thanks
