Installing Als a-arms
cowdogg
Chandler, AZ
My memory of the install isn't that great (which means it wasn't too difficult) but I do know you need several inches (18 or so) of extension on your ratchet to reach the rear on the drivers side. If you have the "wobble" type it helps too as it allows you to loosen it at a greater angle. Hope that helps.
lostrenegade
Pinckney, MI
MoladoGuy said:
Also, pump the ball joints with grease to ensure they are good to go. Check them again within 1 week. I love my set!!
Yes, they are great! I just put mine on a month ago. The only tricky part about the install is everything that has to be removed to get to the bolts; battery, battery tray and I had to undo the break line.
