Hey all. Ive had this little problem with my 04 renegade. I dont have any power when key is off the ignition. Only power seats work. No exterior lights no interior lights or anything. When key is turned all the way up (but i dont start the car) It works fine and when the key is all the way down (when you cant remove the key but the radio works and lights i guess) it seems to work fine. Called dealership and they said they had the same problem with a grand cherokee not so long ago and the problem was the ignition switch. Does that make sense to any of you? Ìt's annoying because i cant use my remotes to lock/unlock i have to put the key in the ignition to use the remotes..,
