What should have taken 45 minutes, took all day to get 6 new working coil packs! :icon_lol:
Some Days..You Can't win for loosing!!!
I will start by saying I had no MIL and random misfires were seen on scanner previously, low count across most of the cylinders just above idle.
To save you the torture to follow, Six new coil packs has smoothed the Jeep's idle out big time! Stopped at light you don't feel the slight misfire shake anymore :gr_grin:
I am still going to want to see it on Snap On scanner again and look for any random misfires, slightly above idle, just in case, 4 nozzle injectors could be next...
Ok I ordered 6 Delphi coil packs, took them home to install and guess what...
I could not get the jeep electrical connector to lock into the Delphi coils..eek.
IDK if the clip up top was narrow or preventing it from locking, but it was at the point if I pushed the connector in any harder, it may have broke the Jeep's connector!
54748[/ATTACH]"]
Going to send Delphi a note and ask them "what's up" as they are suppose to be OEM, and the part # is right...eek.
54750[/ATTACH]"]
Back on phone at Noon to get another brand today. Standard was available and would be in by 3;30 pm...
54752[/ATTACH]"]
Right On!!! The electrical clip slid right in and locked easily..just the way it should be!
One of the Standard was missing an o-ring..
54754[/ATTACH]"]
so I just moved one over from the Mopar to get it installed right, ya the top seal was folded up too...
Sure makes you wonder about quality control, maybe this was a return? :icon_lol:
Anyways, I am Thankful Jeep likes the new coil packs!
arty52:
Since both the recent TPS 1700 rpm surging & coils are not throwing codes...or MIL..
It makes me wonder if it takes 2000 misfires to trigger the light or something..
Maybe we should consider coil packs as a recommended tune up procedure, just like spark plug wires!
Replace them if your Jeep is mis behaving, and 60 k miles or less may very well be the life of them IDK...
BTW.. There is a way with a low amp current probe & a Snap On Scanner to diagnose each firing coil individually!
Link: https://www.youtube.com/watch?v=CR32Lpt623M
I just used the 6 parts cannon method, & my buds shop needs a probe and someone that knows how to run it! LOL!
54748[/ATTACH]"]
54750[/ATTACH]"]
54752[/ATTACH]"]
54754[/ATTACH]"]
